1995_fzr600r
NOTE
This is for the 1995 FZR600R & was sold overseas. In the US, this bike was known as the YZF600.
Year1995 600R
Capacity599
Bore x Stroke62 x 49.6 mm
Max power (rear tyre)99 hp @ 11500 rpm (rear tyre 90.9 hp @ 11400 rpm )
Transmission6 speed
Front Brakes2x 298mm discs same as fzr600 89-93 4 piston calipers
Front Tire120/60 ZR17
Rear Tire160/60 ZR17
Dry Weight184 kg (405.65 lbs)
Standing ¼ Mile11.1 sec / 194.8 km/h (121.05 mph)
Top Speed238.2 km/h (148.02 mph)
1995_fzr600r.1302780755.txt.gz · Last modified: 2020/10/19 11:48 (external edit)
