1993_fzr600
Year1993
Capacity599
Bore x Stroke59 x 54.8 mm
Induction4x 32mm Mikuni BDST32
Max power (rear tyre)901 hp 606.3 kW @ 10500 rpm
Max Torque605.7 Nm @ 8500 rpm
Front Tire110/70-17
Rear Tire140/60-18
Dry Weight181 kg
Fuel Capacity18 Litres
Consumption average18.7 km/lit
Braking 60 - 0 / 100 - 013.3 m / 36.88m
Standing ¼ Mile11.4 sec / 189.0 km/h
Top Speed237.1 km/h
1993_fzr600.1228222353.txt.gz · Last modified: 2020/10/19 11:46 (external edit)
