1991-92_fzr_1000_exup
Year1991-92 FZR1000 (EXUP) EngineLiquid cooled, four stroke, 35° forward inclined transverse four cylinder, DOHC, 5 valves per cylinder. Capacity1002 Bore x Stroke75.5 x 56 mm Compression Ratio12.0:1 Induction4x 38mm Mikuni BDST Ignition / StartingDigital / electric Max power (rear tire)145 hp 105.7 kW @ 10000 rpm (rear tyre 131.7 hp @ 10500 rpm) Max Torque10.9 kg-m 107 Nm @ 8500 rpm Transmission / Drive5 Speed / chain Front Suspension43mm Telehydraulic for adjustable preload, 120mm wheel travel. Rear SuspensionGas/oil single shock, rising rate adjustable preload and damping. 130mm wheel travel. Front Brakes2x 320mm discs 4 piston calipers Rear BrakesSingle 267mm disc 1 piston caliper Front Tire130/60 VR17 Rear Tire170/60 VR17 Dry Weight / Wet-Weight209 kg / 236 kg Fuel Capacity19 Litres Consumption average16.3 km/litres Braking 60 - 0 / 100 - 013.1 m / 37.0m Standing ¼ Mile10.1 sec / 216.8 km/h Top Speed290 km/h
info about the 1992 fzr 1000 swingarm and wheel.
  • A) width of the inside of the swingarm where the wheel's axle gets in is 267 mm.
  • B) width of the wheel with sproket carier on, from bearing to bearing is 210 mm.
C) each side wheel spacer's width is 13 mm. D) caliper bracket's width is 27-28 mm. E) A)+B)+C)+D) = 264 mm. F) A)- E) = 3mm (calculated error by Yamaha so you can slide the whole wheel assembly in)
Supplied by TrifGeorge
1991-92_fzr_1000_exup.1302362702.txt.gz · Last modified: 2020/10/19 11:49 (external edit)
