1991-92_fzr600
| Year | 91-92 | |
| Capacity | 599cc | |
| Induction | 4x 32mm Mikuni BDST32 | |
| Front Tire | 110/70-17 | |
| Rear Tire | 140/60-18 | |
| Dry Weight | 181 kg | |
| Consumption average | 18.7 km/lit | |
| Braking 60 - 0 / 100 - 0 | 13.3 m / 36.88m | |
| Standing ¼ Mile | 11.4 sec / 189.0 km/h | |
| Top Speed | 237.1 km/h | |
1991-92_fzr600.1211437199.txt.gz · Last modified: 2020/10/19 11:46 (external edit)
