1989_fzr_1000_exup
Year1989
EngineLiquid cooled, four stroke, 35° forward inclined transverse four cylinder, DOHC, 5 valves per cylinder, EXUP exhaust control system
Capacity1002
Bore x Stroke75.5 x 56 mm
Induction4x 38mm Mikuni BDST
IgnitionDigital / electric
Max power (rear tire)145 hp 105.7 kW @ 10000 rpm (rear tyre 131.7 hp @ 10500 rpm)
Max Torque10.9 kg-m 107 Nm @ 8500 rpm
Transmission5 Speed / chain
Front Suspension43mm Telehydraulic for adjustable preload, 120mm wheel travel.
Rear SuspensionGas/oil single shock, rising rate adjustable preload and damping. 130mm wheel travel.
Front Brakes2x 320mm discs 4 piston calipers
Rear BrakesSingle 267mm disc 1 piston caliper
Front Tire130/60 VR17
Rear Tire170/60 VR17
Dry Weight209 kg / 236 kg
Consumption average19 Litres
Braking 60 - 0 / 100 - 013.1 m / 37.0m
Standing ¼ Mile10.1 sec / 216.8 km/h
Top Speed273.4 km/h
1989_fzr_1000_exup.1212193058.txt.gz · Last modified: 2020/10/19 11:47 (external edit)
