1989_fzr400r
| Year | 1989 | |
| Engine | Liquid cooled, four stroke, transverse four cylinder, DOHC, 4 per cylinder | |
| Capacity | 399 | |
| Compression Ratio | 11.5:1 | |
| Max power (rear tyre) | 59hp@ 12,000rpm | |
| Max Torque | 3.9kg-m @9,500rpm | |
| Transmission | 6 speed | |
| Front Suspension | 41mm Telescopic forks | |
| Rear Suspension | Monoshock single shock preload adjustable | |
| Front Tire | 110/70-17 | |
| Rear Tire | 140/60-18 | |
| Dry Weight | 165kg | |
1989_fzr400r.1211346028.txt.gz · Last modified: 2020/10/19 11:46 (external edit)
