1987_fzr750_genesis
Year1987 FZR750 (GENESIS)
Capacity749cc
Bore x Stroke68 x 51.6 mm
Compression Ration11.2:1
Induction4x 34mm Mikuni carb
Ignition / StartingElectronic triggered / Electric
Max power (rear tire)106 hp 77.4 KW @ 10500 rpm ( 92.5 hp @ 10500 rpm )
Max Torque7.2 kg-m @ 8250 rpm
Transmission / Drive6 Speed / Chain
Front Suspension41mm Kayaba forks 130mm wheel travel adjustable for spring preload and rebound damping.
Rear SuspensionMonoshock single Kayaba damper 30mm wheel travel adjustable for spring preload and rebound damping.
Front Brakes2x 320mm disc 2 piston caliper
Rear BrakesSingle 267mm disc 2 piston caliper
Front Tire120/70 VR17
Rear Tire160/60 VR18
Dry-Weight / Wet-Weight213 kg / 235 kg
Fuel Capacity20 Litres
Consumption average18 km/lit
Braking 60 - 0 / 100 - 013.5 m / 38.9 m
Standing ¼ Mile11.2 sec / 195.6 km/h
Top Speed270.2 km/h
1987_fzr750_genesis.1287829759.txt.gz · Last modified: 2020/10/19 11:49 (external edit) · Currently locked by: 216.73.216.50,10.1.235.225
