tci-repair
Differences
Link to this comparison view
Next revision
Previous revision
tci-repair [2009/10/02 17:22] – 127.0.0.1tci-repair [2020/10/19 11:50] (current) – external edit 127.0.0.1
Line 14: Line 14:
 A picture of the "works" of a FZR TCI unit  with the TCI unit. A picture of the "works" of a FZR TCI unit  with the TCI unit.
 +The replacement transistor is a Bosch BIP373 IGBTs (about 8USD from autozone )
Line 22: Line 23:
 Best of Luck TrifGeorge Best of Luck TrifGeorge
 +==== Some new information:- ====
 +{{:fzr600-tdi-board.jpg|}}
 +From this picture :- Top to bottom:
 +   *  resistor Br B R Gd = 1k, 5%
 +  * Zener, unknown,
 + band left in the pic. "A2" marking on the side; no idea what the rating is. Logic suggests it's either 5v or 12v; try 5v first so you don't burn anything that doesn't like 12v!
 +  * resistor Bl R Br Gd = 620, 5%
 +  * resistor R R R Gd = 2.2k, 5%
 +The tach signal is tied into the 2-3 spark signal. The earlier model tachs simply picked up the fly-back pulse from the coil, while the newer tachs want a 12v or 5v signal from the TCI (not sure which voltage; this will very likely be tied into the Zener diode rating).
 +The tach may come back to life once you replace the TO-220 ignition transistor.
 +**//Info supplied by DONTZ125,  Picture by AndersJ//**
 ===== Editted extras by Y-G & supplied by ReelRazor ===== ===== Editted extras by Y-G & supplied by ReelRazor =====
tci-repair.1254522173.txt.gz · Last modified: 2020/10/19 11:46 (external edit) · Currently locked by: 216.73.216.42,10.1.138.54
