synch_tool
Differences
| Both sides previous revisionPrevious revisionNext revision | Previous revision | ||
| synch_tool [2010/12/07 21:04] – 127.0.0.1 | synch_tool [2020/10/19 11:50] (current) – external edit 127.0.0.1 | ||
| Line 7: | Line 7: | ||
| If you are thinking about building a carb sync tool, then I would recommend using the 2-bottle method. | If you are thinking about building a carb sync tool, then I would recommend using the 2-bottle method. | ||
| - | I just used it and it works wonders! SUPER fine tuning...My bike revs so smooth now. it sounds so beautiful.Iv tried the stick and tubing method, all I can say is, it sucks and you can risk sucking liquid into your motor. | + | I just used it and it works wonders! SUPER fine tuning...My bike revs so smooth now. it sounds so beautiful.Iv tried the stick and tubing method, all [[http:// |
| ==== Material List ==== | ==== Material List ==== | ||
synch_tool.1291777456.txt.gz · Last modified: 2020/10/19 11:48 (external edit)
