r6_99-02_r6_fork_swap
Differences
Link to this comparison view
Next revision
Previous revision
r6_99-02_r6_fork_swap [2009/01/31 16:10] – 71.56.48.81r6_99-02_r6_fork_swap [2023/07/05 13:46] (current) – 192.168.1.1
Line 1: Line 1:
-====== THIS IS WHAT I HAVE TO WORK WITH: ======+====== THIS IS WHAT I HAVE TO WORK WITH ======
 +[[http://fzrsupport.com/forum/viewtopic.php?f=30&t=2561]]
 +  * This mod will allow you to use any year or make fork setup on your FZR
 +  * By using a threaded rod in 1/2inch or 5/8inch you are able to use any
 +year model or make for this build. My first set of bushings were single sided
 +and r6 stem was chopped to use for taking up the slack in the upper and lower
 +triple holes.
 +  * We now have come up with a design to use a double ended bushing on the top
 +and bottom of the triple and bearings. It will serve as taking up slack in the triples
 +and providing a place for the bearings to rest on. Oem bearings are retained in this
 +mod.
 +  * The 1st set of bushings were made from 6061 Aluminum Rod. These are still in place
 +and used in my bike. I will give a 500 mile and 1000 mile inspection this summer.
 + We have now changed to Steel Double Sided bushings giving it a more solid fit for
 + added security and tolerances.
 +  * I want to thank (Rob) CAD600 for everything on this build. Together we will be
 +able to provide the bushings for any fork build you may have.
 +  * I have purchased my own metal lathe and will be producing bushings for this mod.
 +If you need anything made let one of us know. Thanks!8-)
 +====== Materials List: ======
 +  * Triples, these are for a 99-02 R6 but any other YEARS / MODEL will work
 +  * Fork Tubes, that match the Triples
 +  * Hardened threaded rod in either 1/2inch or 5/8inch
 +  * Double ended bushings (contact cad600 or 95FZR600)
 +  * Clipons, that match the forks
 +  * Wheel / Brakes, that match the forks
 +  * Use your existing FZR bearings,spacers and dust caps
 {{:r6_triples.jpg|}} {{:r6_triples.jpg|}}
-====== 2 Bushings need to be made for upper and lower triples ======+====== 2 Bushings need to be made for upper and lower triples: ======
 {{:img1687fm1.jpg|}} {{:img1687fm1.jpg|}}
 +====== After bushings were made to fit: ======
 +  * The OEM stem was cut at the bottom triple and used for a bushing
 +  * I also cut the OEM stem at the top below both sets of threads and used at the top
 +  * In the future we will be using a double ended bushing for top and bottom and the OEM stem will not be used.
 +{{:img1705yw7.jpg|}}
 +{{:img1706iz4.jpg|}}
 +====== THIS IS HOW IT WILL BE INSTALLED ON BIKE ======
 +  * I want to thank (rob) cad600 for the use of his bike and also designing the bushings
 +  * Once the bushings were cut we were able to install them on his bike (FZR600)
 +  * You can see the bushings are to take up space of the OEM stem
 +  * The OEM needle bearings and dust covers were used from the FZR
 +{{:steering01.jpg|}}
 +{{:steering02.jpg|}}
 +{{:steering03.jpg|}}
 +{{:steering04.jpg|}}
 +{{:steering05.jpg|}}
 +{{:steering06.jpg|}}
 +{{:steering08.jpg|}}
 +{{:steering09.jpg|}}
 +{{:steering10.jpg|}}
 +{{:steering11.jpg|}}
 +{{:steering12.jpg|}}
 +{{:steering13.jpg|}}
 +{{:steering14.jpg|}}
 +{{:forks2.jpg|}}
 +Contact: Cad600 or 95FZR600 for bushings
 +===== UPDATE from TONY FOALE on the Design =====
 +see:-[[http://fzrsupport.com/forum/viewtopic.php?f=30&t=2561&start=105]]
 +OR
 +Pix entitled "BottomYoke., Bottom Yoke 1, Bottom yoke 2, Bottom yoke 3..." at
 +[[http://www.tonyfoale.com/AermacchiFrame/?N=A]]
 +==== Editted by Y-G on 2010-01-05 ====
r6_99-02_r6_fork_swap.1233439845.txt.gz · Last modified: 2020/10/19 11:46 (external edit)
