Differences
Link to this comparison view
Next revision
Previous revision
led_instrument_warning_lamp_conversion [2010/05/14 05:50] – 127.0.0.1led_instrument_warning_lamp_conversion [2020/10/19 11:51] (current) – external edit 127.0.0.1
Line 73: Line 73:
 High-beam, Yellow Positive, Black Negative High-beam, Yellow Positive, Black Negative
-Turn/Blinker dark/Green Positive, dark/Brown Positive (light/Green some US models)+Turn/Blinker, dark/Green Positive, dark/Brown Positive (light/Green some US models)
-Neutral, Brown Positive, light/Blue Negative+Neutral Brown Positive, light/Blue Negative
 Oil, Brown Positive, Black/Red Negative Oil, Brown Positive, Black/Red Negative
Line 89: Line 89:
 {{:turncloseup.jpg|}} {{:turncloseup.jpg|}}
-The holder cut off, i left around 1 inch of wire on the holder, the small piece of wire top left i cut that amount from both wires loom/harness side, so the wires tuck back in tidily don't want them to long+The holder cut off, i left around 1 inch of wire on the holder, the small piece of wire top right i cut that amount from both wires loom/harness side, so the wires tuck back in tidily don't want them to long
 {{:turncut.jpg|}} {{:turncut.jpg|}}
led_instrument_warning_lamp_conversion.1273834247.txt.gz · Last modified: 2020/10/19 11:47 (external edit)
