Differences
Link to this comparison view
Next revision
Previous revision
led_instrument_warning_lamp_conversion [2010/05/14 05:41] – 127.0.0.1led_instrument_warning_lamp_conversion [2020/10/19 11:51] (current) – external edit 127.0.0.1
Line 73: Line 73:
 High-beam, Yellow Positive, Black Negative High-beam, Yellow Positive, Black Negative
-Turn/Blinker dark/Green Positive, dark/Brown Positive (light/Green some US models)+Turn/Blinker, dark/Green Positive, dark/Brown Positive (light/Green some US models)
-Neutral, Brown Positive, light/Blue Negative+Neutral Brown Positive, light/Blue Negative
 Oil, Brown Positive, Black/Red Negative Oil, Brown Positive, Black/Red Negative
Line 89: Line 89:
 {{:turncloseup.jpg|}} {{:turncloseup.jpg|}}
-The holder cut off, i left around 1 inch of wire on the holder, the small piece of wire top left i cut that amount from both wires loom/harness side, so the wires tuck back in tidily don't want them to long+The holder cut off, i left around 1 inch of wire on the holder, the small piece of wire top right i cut that amount from both wires loom/harness side, so the wires tuck back in tidily don't want them to long
 {{:turncut.jpg|}} {{:turncut.jpg|}}
Line 117: Line 117:
 {{:hbeamgroundbared.jpg|}} {{:hbeamgroundbared.jpg|}}
-Taped up and finished (sorry for the blurry photo)+Taped up and finished (sorry for the blurry photo), just need to fit the other 3 led's make sure the anode (Positive) goes to the corresponding lamp positive
 +High-beam, Yellow Positive, Black Negative
 +Neutral, Brown Positive, light/Blue Negative
 +Oil, Brown Positive, Black/Red Negative
 {{:lampsreardone.jpg|}} {{:lampsreardone.jpg|}}
 +The led's working
 +{{:neutturnhbillum.jpg|}}
 +{{:oilneutturnillum.jpg|}}
 +Inside the speedo lamp covers removed, you may need to do this depending on how bright your led's are (i had to) 10mm led top, 5 mm led bottom, the extra 10m led i added side
 +{{:speedoleds.jpg|}}
 +Close up of the extra led, i soldered it to the top led legs, fixed it to the speedo body with double sided foam sticky tape
 +{{:speedoleds1.jpg|}}
led_instrument_warning_lamp_conversion.1273833666.txt.gz · Last modified: 2020/10/19 11:46 (external edit)
