how_to
Differences
Link to this comparison view
Next revision
Previous revision
how_to [2008/06/08 23:17] 67.166.244.247how_to [2020/10/19 11:50] (current) – external edit 127.0.0.1
Line 24: Line 24:
      * Remove top right first, then top left, then bottom right, then bottom left      * Remove top right first, then top left, then bottom right, then bottom left
-  :!: You must loosen the bolts evenly starting with the middle bolts.  Only loosen a few revolutions at a time.  If you don't do this the bridge will break! +:!: You must loosen the bolts evenly starting with the middle bolts.
- +:!: Only loosen a few revolutions at a time.  If you don't do this the bridge will break!
-{{:valve1.jpg|}} +
-{{:valve2.jpg|}} +
-{{:valve3.jpg|}} +
-{{:valve4.jpg|}} +
-{{:valve5.jpg|}} +
-{{:valve6.jpg|}} +
-{{:valve7.jpg|}} +
-{{:valve8.jpg|}} +
 +{{:valve1.jpg?180|}}
 +{{:valve2.jpg?180|}}
 +{{:valve3.jpg?180|}}
 +{{:valve4.jpg?180|}}\\
 +{{:valve5.jpg?180|}}
 +{{:valve6.jpg?180|}}
 +{{:valve7.jpg?180|}}
 +{{:img_0257.jpg?180|}}
 +{{:img_0258.jpg?180|}}
 +{{:img_0259.jpg?180|}}
 +{{:img_0260.jpg?180|}}
 +{{:img_0263.jpg?180|}}
 +{{:img_0264.jpg?180|}}
 +{{:img_0265.jpg?180|}}
 +- icontender
how_to.1212985029.txt.gz · Last modified: 2020/10/19 11:49 (external edit)
