how_to
FIXME
  • Difficulity: medium
  • Attention to detail: medium
  • Remove valve cover (8mm)
  • Remove chain guard
:!: You must loosen the bolts evenly starting with the middle bolts.  Only loosen a few revolutions at a time.  If you don't do this the bridge will break!
how_to.1212985029.txt.gz · Last modified: 2020/10/19 11:49 (external edit)
