how_to
Differences
Link to this comparison view
Next revision
Previous revision
how_to [2008/05/27 20:34] 72.207.25.15how_to [2020/10/19 11:50] (current) – external edit 127.0.0.1
Line 1: Line 1:
 +FIXME
 ==== How to adjust your valve clearances ==== ==== How to adjust your valve clearances ====
 This is incomplete but please feel free to edit this if you have knowledge on this matter This is incomplete but please feel free to edit this if you have knowledge on this matter
Line 17: Line 19:
 Removed Cons:  adds additional time and requires more tools.  Removed Cons:  adds additional time and requires more tools.
 +  * Remove valve cover (8mm)
 +  * Remove chain guard
 +  * Remove bridges one at a time
 +     * Remove top right first, then top left, then bottom right, then bottom left
 +:!: You must loosen the bolts evenly starting with the middle bolts.
 +:!: Only loosen a few revolutions at a time.  If you don't do this the bridge will break!
 +{{:valve1.jpg?180|}}
 +{{:valve2.jpg?180|}}
 +{{:valve3.jpg?180|}}
 +{{:valve4.jpg?180|}}\\
 +{{:valve5.jpg?180|}}
 +{{:valve6.jpg?180|}}
 +{{:valve7.jpg?180|}}
 +{{:img_0257.jpg?180|}}
 +{{:img_0258.jpg?180|}}
 +{{:img_0259.jpg?180|}}
 +{{:img_0260.jpg?180|}}
 +{{:img_0263.jpg?180|}}
 +{{:img_0264.jpg?180|}}
 +{{:img_0265.jpg?180|}}
 +- icontender
how_to.1211938450.txt.gz · Last modified: 2020/10/19 11:48 (external edit)
