brake_rotors_from_other_models
Differences
Link to this comparison view
Next revision
Previous revision
brake_rotors_from_other_models [2008/10/03 10:38] – created 80.177.31.81brake_rotors_from_other_models [2020/10/19 11:50] (current) – external edit 127.0.0.1
Line 1: Line 1:
-There are plenty of discs about that will fit the FZR - Range
-Yamaha shares this rotors: +There are plenty of discs about that will fit the FZR - Range 1000 & 750's WITH 320MM FRONTS, NOT REARS.
 +Yamaha shares this rotor:
  Specs:  Specs:
Line 8: Line 10:
 - inner diameter: 64 mm - inner diameter: 64 mm
-- thickness: 5 mm+- thickness: 4 mm
-- setback: 10,5 mm:  +- offset: 9.5 mm
 +BOLT PATTERNS ARE THE SAME
 +WITH YAMAHA Models:
 +- FZ 1000 R from 1987 till 1989
 +- FZR 1000 EXUP from 1989 till 1995
 · FZR 250 87- · FZR 250 87-
-· TDR 250 88-92+· FZR 750 Genesis 87
-· TZR 250 87-92+· FZR 1000 Genesis 87-88
 +· FZR 1000 EX-UP 89-95
 · SRX 400 (3VN1/3VN2/3VN5) 90-96 · SRX 400 (3VN1/3VN2/3VN5) 90-96
Line 24: Line 36:
 · SZR 660 96-97 · SZR 660 96-97
-· FZR 750 Genesis 87+· TDR 250 88-92
-· YZF 750 R/SP 93-97+· TZR 250 87-92
-· FZR 1000 Genesis 87-88+· XJR 1200 from 1994 till 1998
-· FZR 1000 EX-UP 89-95+· XJR 1300 (5EA1) 98
-· XJR 1200 95-98+· YZF 750 R/SP 93-97
-· XJR 1300 (5EA1) 98+- YZF 750 R from 1993 till 1995
 To make the list complete: To make the list complete:
Line 88: Line 101:
 - 1000 MOSTRO from 2003 - 1000 MOSTRO from 2003
-YAMAHA: +the FZR600 uses 298mm diameter discs 64mm inner diameter 4mm thick minimum thickness is 3.5mm the discs are fitted to FZR600 1989-93 FZR600R 1994-95
- +after this date the discs are 320mm (yzf600r) as fitted to the fs6 and R6 etc
-- YZF 750 R from 1993 till 1995 +
-- FZ 1000 R from 1987 till 1989 +
-- FZR 1000 EXUP from 1989 till 1995+
-- XJR 1200 from 1994 till 1998+I Hope it helps someone struggling to find replacements!!!!!!!
 +- Ozzyfzr
-Hope it helps someone struggling to find replacements!!!!!!!+//Thanks Guy well done Y-G//
-provide by Ozzyfzr
-Thanks Guy well done Y-G
brake_rotors_from_other_models.1223048329.txt.gz · Last modified: 2020/10/19 11:47 (external edit) · Currently locked by: 216.73.216.42,10.1.138.54
