Temperature Gauge
Temperature Gauge
When I go riding, the temperature gauge usually reads about half way. Once it hits half way, it rockets up to the redzone. After I turn off the bike, let the needle fall, and turn it back on, without riding, the needle sits at the middle. Is this a problem with the spring or the thermostat? Any spring kits out there?
Re: Temperature Gauge
Your thermostat may be bad, or you have air in your system. Take your thermostat out and put it in a pot of water and bring it to a boil. It should open well before the water boils.
