idle adjust
idle adjust
Where is it? I'm up in Ruidoso, NM on vacation with the fam, and I'm idling at about 700
, down from 1100.
- William Burroughs
- Karl Marx
- William Burroughs
- Karl Marx
Re: idle adjust
one of the frame plugs should get you access to a big phillips headed dial you can turn to adjust idle
SOLD
SOLD
Re: idle adjust
gratzi my friend.
- William Burroughs
- Karl Marx
- William Burroughs
- Karl Marx
Re: idle adjust
ok, I checked it out and took all the frame plugs off, but couldn't find a phillips head dial. Where exactly is it located?
- William Burroughs
- Karl Marx
- William Burroughs
- Karl Marx
- megaloxana
Re: idle adjust
Its the knob supported by the bracket at the bottom left side of the picture
(picture courtesy of ragedigital
Re: idle adjust
thats the one
it might not be located there on the 600....let me go look!
SOLD
SOLD
Re: idle adjust
aight.
so that sits under where the choke is mounted to the frame
with sidecovers it'll be annoying to get to
SOLD
SOLD
Re: idle adjust
alright, I found it. Thanks again!
- William Burroughs
- Karl Marx
- William Burroughs
- Karl Marx
Re: idle adjust
I need to replace that photo with one that doesn't have a bunch of the float bowl cover screws misssing...megaloxana wrote:(picture courtesy of ragedigital)
Also, that tubing on the right side is from an EXUP equipped bike. They have since been removed.
Re: idle adjust
You trying to save weight there Darrin?ragedigital wrote:I need to replace that photo with one that doesn't have a bunch of the float bowl cover screws misssing...
Re: idle adjust
no problem.ian wrote:alright, I found it. Thanks again!
SOLD
SOLD
