idle adjust
ian
Level 2.5
Level 2.5
idle adjust
Post by ian »
Where is it? I'm up in Ruidoso, NM on vacation with the fam, and I'm idling at about 700 :yikes: , down from 1100.
Thanks, for a country where nobody is allowed to mind his own business. Thanks, for a nation of finks.
- William Burroughs
haha this is awesome... probably the only addiction support group i have seen that supports the addiction!
Last words are for fools who haven't said enough.
- Karl Marx
haunter
Re: idle adjust
Post by haunter »
one of the frame plugs should get you access to a big phillips headed dial you can turn to adjust idle
ian
Level 2.5
Level 2.5
Re: idle adjust
Post by ian »
gratzi my friend.
- William Burroughs
- Karl Marx
ian
Level 2.5
Level 2.5
Re: idle adjust
Post by ian »
ok, I checked it out and took all the frame plugs off, but couldn't find a phillips head dial. Where exactly is it located?
- William Burroughs
- Karl Marx
megaloxana
Re: idle adjust
Post by megaloxana »
Its the knob supported by the bracket at the bottom left side of the picture
(picture courtesy of ragedigital :deal:)
'92 FZR 600
haunter
Re: idle adjust
Post by haunter »
thats the one
it might not be located there on the 600....let me go look!
haunter
Re: idle adjust
Post by haunter »
aight.
so that sits under where the choke is mounted to the frame
with sidecovers it'll be annoying to get to
ian
Level 2.5
Level 2.5
Re: idle adjust
Post by ian »
alright, I found it. Thanks again!
- William Burroughs
- Karl Marx
ragedigital
4000+ Posts
4000+ Posts
Re: idle adjust
Post by ragedigital »
megaloxana wrote:(picture courtesy of ragedigital :deal:)
I need to replace that photo with one that doesn't have a bunch of the float bowl cover screws misssing... :whistle
Also, that tubing on the right side is from an EXUP equipped bike. They have since been removed.
tommyj27
Level 9.5
Level 9.5
Re: idle adjust
Post by tommyj27 »
ragedigital wrote:I need to replace that photo with one that doesn't have a bunch of the float bowl cover screws misssing... :whistle
You trying to save weight there Darrin?
haunter
Re: idle adjust
Post by haunter »
ian wrote:alright, I found it. Thanks again!
no problem. :shocker
