Removing the upper triple
delvryboy
Level 5.0
Level 5.0
Post by delvryboy »
Do I need to support the front end to remove the upper triple clamp only?
'92 FZR600
Lots of Powder
haro504
Level 7.5
Level 7.5
Re: Removing the upper triple
Post by haro504 »
i dont think you have to but i would i deffinatly wouldent leave it that way long if you dont
delvryboy
Level 5.0
Level 5.0
Post by delvryboy »
I'm just going to be swapping uppers.
'92 FZR600
Lots of Powder
So long as your lower screws are tight, you'll be fine. Ummm - make sure they're tight before you pull the upper; you never know what some thud of a PO has done...
delvryboy
Level 5.0
Level 5.0
Post by delvryboy »
Thanks
'92 FZR600
Lots of Powder
pefrey
Level 5.5
Level 5.5
Post by pefrey »
I've done it but I don't recommend it. The upper triple is going to be a bitch to put back on. You need to unweight the front.
