Removing the upper triple
Do I need to support the front end to remove the upper triple clamp only?
'92 FZR600
Lots of Powder
Lots of Powder
Re: Removing the upper triple
i dont think you have to but i would i deffinatly wouldent leave it that way long if you dont
I'm just going to be swapping uppers.
'92 FZR600
Lots of Powder
Lots of Powder
So long as your lower screws are tight, you'll be fine. Ummm - make sure they're tight before you pull the upper; you never know what some thud of a PO has done...
'92 FZR600
Lots of Powder
Lots of Powder
I've done it but I don't recommend it. The upper triple is going to be a bitch to put back on. You need to unweight the front.
