clutch slip
clutch slip
i am having trouble with my clutch as in slipping when cold at around 8000 rpm i took it apart fibers are new the steels looked ok but to were burnt so i replaced them and it still does it. also the clutch handle has to be fully released to ingaged . i tried bleading it and it didnt help? what should i try next
- Fizzinatorr
- Level 6.5
Re: clutch slip
this is for the FZR 1000 right?
Re: clutch slip
Fizzinatorr wrote:this is for the FZR 1000 right?
PLUS where in the world are you as the market model varies. !!!
When you assembled the steels they all had the sharp edges facing the same way RIGHT?
if not it is prone to slippages as the plates have a slight bevel on them from the stamping press the day they are made.
Some yamaha corks are also mounted on alloy and can warp so check those on a piece of plate glass or a machine shop surface plate.(polished grave stones are of use as well.)
Re: clutch slip
yes its a 91 fzr 1000 im in cali but i beleave its a non cali bike as there are noneof the emision things on it.
Re: clutch slip
You've checked the master cylinder and slave cylinders for leaks? Doesn't sound like that's where the problem is though. Sounds like the fiber disks have lost their grip
Re: clutch slip
i noticed that when i pulled the slave cilinder it slowly exstended out almost like i squeased the handle.. i used a small c clamp and pushed it back in to its bore then removed clamp and it slowly came right back out ..is this normal??
Re: clutch slip
No it sounds as though you have air in the system, when it is in place the air is compressed but as soon as you take the pressure of the piston it expands and pushes the piston out and thus gives you a mushy clutch as you have experienced.wheily wrote:i noticed that when i pulled the slave cilinder it slowly exstended out almost like i squeased the handle.. i used a small c clamp and pushed it back in to its bore then removed clamp and it slowly came right back out ..is this normal??
Re: clutch slip
so i need to get it bled then and try again..would that also be why to dissingage clutch i only need to pull handle a 1/2 inch
Re: clutch slip
ok i bled every thing made sure all steels are facing same way and still slips in the higher rpm. could it be my clutch springs are just not strong enough ? the reason i ask is after about 10 miles or so when the moters hot it dosent slip any more only when bike is below a sertain temp. also does any one know what sise the o ring is on the clutch side cover the first time i pulled itt the p.o. had black tape rapped around the little tube and i didnt get one with new cover gasket so i used a o ring for a pressure washer tip it fit but id like to have the corect one in there.. thanks
