I dont know about you guys but around here they charge 50$ per rim to change tires or 45 if you buy the tires there and take the wheel off the bike.
I found these instructional videos on youtube.com that work really really well.
Change your own bike tires
1992 FZR 600
Yoshi exhaust
K&N pods
Airtech R1-kit
02 R6 fork swap
02 R6 Swingarm
520 chain conversion
07 R6 controls
Vortex R6 clipons
07 R6 radial master
2003 CBR 600rr
bone stock
Re: Change your own bike tires
We have No-Mar Tire Changers in St. Louis where they'll change them for free for MCRA members. They are great folks and have an incredible product!
If you change tires quite a bit, I would look into something more substantial, otherwise I would find someone who races local who might do it cheaper than a stealership.
Before I knew about No-Mar, a local racer would change/balance ours for $15 a rim.
darrin
darrin
R3,R3TARD wrote:I dont know about you guys but around here they charge 50$ per rim to change tires or 45 if you buy the tires there and take the wheel off the bike.
on Saltmine.org.uk Jim Stewart has a How-to use the Harbour Fright tyre machine which is considerably less effort especially on busting the bead off the rim with a tyre that has seen some mileage & years
- Level 8.0
This is awsome... Local shops they charge 50 bucks to swap tires, which amounts to the money you saved by buying online. I'm gonna replace the tires on the FZR this spring i'm gonna try this.
NO FZR
05 Yamaha R1
03 Harley Fatboy
what's next?
05 Yamaha R1
03 Harley Fatboy
what's next?
i can get them on no problem but one tire i couldent get the bead off and eventually cut the tire off the rim. it was almost glued to the rim i pealled it off. im cheap i do my car an truck tires the same way
H,haro504 wrote:i can get them on no problem but one tire i couldent get the bead off and eventually cut the tire off the rim. it was almost glued to the rim i pealled it off. im cheap i do my car an truck tires the same way
that is why Jim Stewart's How to is so good darned if I wanna be cutting tyres
