Pipe rubbing on the swingarm.
delvryboy
Level 5.0
Level 5.0
Post by delvryboy »
I just noticed it, I thought I felt a weird vibration. Its obviously been like this for awhile as the paint is worn off and there is some surface rust on the swingarm.
Should I bend the hanger out some, or just put some washers in between the pipe hanger and the mounting flange?
Thanks
'92 FZR600
Lots of Powder
reelrazor
Wrench
Wrench
Re: Pipe rubbing on the swingarm.
Post by reelrazor »
Stock pipe? Aftermarket? Which brand?
Could be just a matter of looseningthe clamps for the mid-pipe and rotating the whole setup a little to gain clearance.
delvryboy
Level 5.0
Level 5.0
Post by delvryboy »
Yoshi slip on. Its bolted to the stock hanger. I'll see if I can rotate it.
'92 FZR600
Lots of Powder
delvryboy
Level 5.0
Level 5.0
Post by delvryboy »
I twisted it up a bit, slid the clamp a little lower, and used a couple of washers as spacers. Its all good now.
Hell, not even sure why I made a thread about this. banghead
'92 FZR600
Lots of Powder
touch
Post by touch »
because the 28 people who have viewed the thread are now rushing out to their bikes to check exhaust clearance. Thanks for spending time with us...
shredex
Post by shredex »
95FZR600 wrote:Mine did that to. Your not the only one and I bet for every fzr swing arm you look at it has rub or scratch marks from the pipe.
not mine :banana: :bunny :yutugh2: :Kick :headbang:
