I just noticed it, I thought I felt a weird vibration. Its obviously been like this for awhile as the paint is worn off and there is some surface rust on the swingarm.
Should I bend the hanger out some, or just put some washers in between the pipe hanger and the mounting flange?
Pipe rubbing on the swingarm.
'92 FZR600
Lots of Powder
Lots of Powder
Re: Pipe rubbing on the swingarm.
Stock pipe? Aftermarket? Which brand?
Could be just a matter of looseningthe clamps for the mid-pipe and rotating the whole setup a little to gain clearance.
Yoshi slip on. Its bolted to the stock hanger. I'll see if I can rotate it.
'92 FZR600
Lots of Powder
Lots of Powder
I twisted it up a bit, slid the clamp a little lower, and used a couple of washers as spacers. Its all good now.
Hell, not even sure why I made a thread about this.
'92 FZR600
Lots of Powder
Lots of Powder
because the 28 people who have viewed the thread are now rushing out to their bikes to check exhaust clearance. Thanks for spending time with us...
- shredex
- 2000+ Posts
not mine95FZR600 wrote:Mine did that to. Your not the only one and I bet for every fzr swing arm you look at it has rub or scratch marks from the pipe.
