thanks
Hi L,Lukather wrote:Hello does anyone have the paint code for my exup... all colours specifically the blue and red..
thanks
You need those too? OK. Tommorow i 'l check it out buddy. Just tell me one thing: is your white a metallic one?Lukather wrote:Brilliant Stuff....thanks you've been briliant...
did you get the red and white...
Many Many thanks
Chris
CS,csofos wrote:You need those too? OK. Tommorow i 'l check it out buddy. Just tell me one thing: is your white a metallic one?Lukather wrote:Brilliant Stuff....thanks you've been briliant...
Many Many thanks
Chris
It's a pearl one. The code is "YAM 4000". And the code for red it's "YAM 3000". I don't know if they are good or not for touch up. Maybe not. The dealer must be right. It's his job and he knows better. BUT...... if you go for a touch up, i would say NO. WHY? Because your 1000 it's an old motorcycle and the colours, (even if you can't see it) have been fade out a kind of. So, if you just touch up, there will be a serious difference between the touch up and the old colour.Lukather wrote:Yes metalic or pearl. I have contacted local touch specialist an they have indicated that sikkens paints are water based and no good for touch up. Can I just use the same codes/colours for touch up ? Your help is greatly appreciated. Chris
