Thanks in advance
Chris
Well first. it has an 18inch wheel (160)...second the swing arm won't fit without modifications.shredex wrote:what is the rear wheel size on the 750?
when you do your swingarm swap (and if it has a wider back wheel than the 600), see if the swinger can fit into a fzr600 frame with no modifications.....
280€!!! No more than 500$zero9243 wrote:how much did you get it for?
Wow... it seems that youknow very well fzrs. I'll follow your instructions. At least some of them...sweekster wrote:I would take it you're going to do a rebuild on the motor? An FZR 1000 motor of the same year will fit in that frame. The 1000 EXUP motor will fit with a bit of frame work. Unless the motor already in there is dead then go with what you have. As said, if you can find a YZF 750 front end (or maybe a ThunderAce?) then swap to that. FZR 1000 EXUP or YZF750 swingarm and rear wheel will bring you to date with more modern tire choices. R1 brakes and Master Cylinder. Also, since this is a track bike, a custom and much lighter subframe should be on the list as well. A proper jet kit and filter for the carbs....
I agree with the engine opinion. I'll see if it's dead or not. The front must leave though. What do you all guys think about a tail from Kawasaki Z-750?shredex wrote:I say, if the motor is in good condition and isnt dead, then you should keep the 750...
not many people have the 750
if you want a 1000, then just buy the 1000...
keep the 750!
and let us know how the 750 rowrs when shes done!
I agree with the r1 front forks...
I'm having a hard time finding a picture of a Z-750 tail. Do you have any photos we can use for reference?csofos wrote:What do you all guys think about a tail from Kawasaki Z-750?
He talking about this (see below) it's the same tail that is on the 03-05 (?) 636 and Z1000.the_finch wrote:I'm having a hard time finding a picture of a Z-750 tail. Do you have any photos we can use for reference?csofos wrote:What do you all guys think about a tail from Kawasaki Z-750?
