hit starter again and "CLICK" then nothing would not even turn on lights, totally dead. Thought maybe battery, took my meter and checked the battery voltage and it was 12.06V, turned the key on and still nothing, with key on I was going to check voltage again, as soon as I touched the Positive terminal with meter lead all the lights came on. Everytime I would pull the lead off lights would go back out, touch it again, lights back on. Water in the battery is full, I pulled the battery and it looks ok, I reinstalled it and made sure all the connections were tight and turned the key on and all seemed ok, started right up and then I noticed that now the only light on the guages that works is the Neutral light, no speedo or Tach backlight, no oil light and now the headlight is not coming on. All other lights are working normally. Blinkers and tail/brake lights. Blinker light will flash on guages when activated. I am now really confused, can't ride it at night now. Does anyone have any ideas? HELP PLEASE. thanks alot for any help or suggestions.
