Todd
then what the hell do I have?cad600 wrote:As far as headlights go, there are really 4 choices. There is the dual headlight model (89-90,93-98), single headlight model (91-92), the UK single dual headlight model (various years and models had them), and the German single dual headlight (fzr 1000 & 600 about 93-95). If you have the US single headlight, the UK and German models will bolt directly in. You only need to modify the wire harness. To swap from he dual to the single or single to the dual you need these parts. Front headlight/fairing bracket (also called the birdcage), front fairing, wind screen, headlight wire harness, air tubes, and the light itself. This swap is a direct bolt on replacement as long as you have all the parts.
If you want to see an example of the UK light, look up Noahs bike in the Bikes For Sale section. For the German light, look up my build in the Hybrid section.
cad600 wrote:US model single headlight (one bulb) 91-92 model year.
Well, I really wanted to make my bike different. But at the same time, I have a thing for the two lights. When I came across the German light, I decided to convert the fairings so I could use it. It's definitely not a cheap endeavor.shredex wrote:cad600 wrote:US model single headlight (one bulb) 91-92 model year.
I can see youve done your research.
