doesnt show full power in first.
- shredex
when im pulling from a stop, the bike revs high but it doesnt seem to be going anywhere fast.
this is only in first gear though.
I couldnt pull out in front of a car thats 200 feet away going 30 because my bike wont get threw first fast enough.
I have better luck keeping it in second the whole time
Re: Digital guage still doesnt work.
hmmm, you wired the gauge to the diagram? did you include the oil relay part?
My FZR6 Rebuild
My FZR6 Rebuild
- shredex
the gauge was working perfectly before I tried to install a turn signal.Genesis wrote:hmmm, you wired the gauge to the diagram? did you include the oil relay part?
once I put the turn signal in and turned the bike on, withought even turning on the signals the light just lite up really bright without blinking. then I turned on the signal button and that when everything stopped working.
fuses?
Upgrades:
- shredex
all fuses are good. The backlight still comes up on the gauge but the numbers and that stuff does not.zero9243 wrote:fuses?
hmmm, so you did te r6 control swap too, sounds like you have a crossed wire, I know it is a lame question, but did you back check all you wiring? and did you check your blinker relay?shredex wrote:the gauge was working perfectly before I tried to install a turn signal.Genesis wrote:hmmm, you wired the gauge to the diagram? did you include the oil relay part?
My FZR6 Rebuild
My FZR6 Rebuild
- shredex
I wasnt the one that did the swap. The previous owner did it.Genesis wrote:hmmm, so you did te r6 control swap too, sounds like you have a crossed wire, I know it is a lame question, but did you back check all you wiring? and did you check your blinker relay?shredex wrote:the gauge was working perfectly before I tried to install a turn signal.Genesis wrote:hmmm, you wired the gauge to the diagram? did you include the oil relay part?
I checked the wiring and there is no loose connections and the reley seemed to be fine.
it only f*cked up when I put the turn signal on in the front. when I did the rear, it worked just fine and blinked.
it sounds like something got grounded, I would double check all you connections, fuses, and the wiring diagram, then go from there. did you go to LED's?I wasnt the one that did the swap. The previous owner did it.
My FZR6 Rebuild
My FZR6 Rebuild
- shredex
I did not get LED's.
and the only fuses I know of are all fine.
theres the fuse box which has like 4 or 5 in it and they are 10's, and theres one fuse all by itself thats like a 25. all the fuses are fine.
im going to wake up tomorroww and quadruple check the wires and connections. Iv checked them many times allready
sounds good man, let me know if you need any diagrams i've accumulated some.shredex wrote:I did not get LED's.
My FZR6 Rebuild
My FZR6 Rebuild
If I remember correctly the previous owner did not finish the install of the gauges.
- shredex
yes, that is correct. BUT, the only thing he didnt finish was installing the speedo scenser into the crank case. everything else was working great.95FZR600 wrote:If I remember correctly the previous owner did not finish the install of the gauges.
I dont remember, you did install the sensor in the case?
- shredex
I havent installed that yet. Im probably just going to bite the bullet and have a pro do it.95FZR600 wrote:I dont remember, you did install the sensor in the case?
but at least i got my gauge working again
