Oil kind??
yamaboy
Level 1.5
Level 1.5
Oil kind??
Post by yamaboy »
Hi again.. :drink:
I'm gonna change my oil and filter/most likely a K&N , and was wondering what oil you guys use..brand and viscosity?
The current temperature is 70F-90F+ ??
Thanks
1995 ,FZR 600,Factory Pro 1.1Ti Jet Kit, Yoshi slipon,K&N filter,elevation 4200 ft above sea level.
Carb settings: Main Jet 110, Starter Jet 52.5,Needle @ 3rd position,23m Floats,about 3 turns IM Screws.
80's-90's,Rap..music.?? http://www.last.fm/listen/user/unsmenar/personal
YAM93
Re: Oil kind??
Post by YAM93 »
Spectro Golden 4 10W-40
Maxima Premium is great also
sweekster
Re: Oil kind??
Post by sweekster »
Was running 20w50 Yamalube for the last 2 years but that's expensive so I'm trying out Castrol 4T Motorcycle Oil (20w50). No issues so far
Fartblood
Level 4.5
Level 4.5
Re: Oil kind??
Post by Fartblood »
I use whatever SL rated 15/40 semi synthetic diesel oil is the cheapest. Petrol oil can contain friction modifiers that harm the clutch, but diesel oil is free of it.
haunter
Re: Oil kind??
Post by haunter »
rotella or rotella syn
bweight
Level 4.0
Level 4.0
Re: Oil kind??
Post by bweight »
Mobil1 20w50 Full Synthetic..
89 FZR 400
Custom Paintjob
600 plastics.
06 - R6 Shock
FZR600 Motor
Soon to be:
Broke........
haunter
Re: Oil kind??
Post by haunter »
I've ran Mobil 1 MX4T before
buts its ~60 bucks a case, thats 2 oil changes for a 600, but not for a 1k
95FZR600
Re: Oil kind??
Post by 95FZR600 »
Royal Purple is the only oil I use in my FZR. 20w50 but in the intruder I run castrol 10w40.
megaloxana
Re: Oil kind??
Post by megaloxana »
I went with the rotella per a topic a while back. Bike hasn't crapped out yet :ermm:
haunter
Re: Oil kind??
Post by haunter »
megaloxana wrote:I went with the rotella per a topic a while back. Bike hasn't crapped out yet :ermm:
I wouldnt worry if I was you
megaloxana
Re: Oil kind??
I wouldn't ride around if I was worried :no
yamaboy
Level 1.5
Level 1.5
Re: Oil kind??
Post by yamaboy »
Nobody is using Valvoline?? I found Valvonline 15w40 motorcycle oil at Autozone pretty cheap..
ragedigital
4000+ Posts
4000+ Posts
Re: Oil kind??
Post by ragedigital »
Shell Rotella 5/40 Full Synthetic
It's helping with the 2nd gear shift problem.
