Moderators: Site Director , FZR Forum Moderators
yamaboy
Level 1.5
Posts: 152 Joined: Thu Aug 14, 2008 8:22 pm
Post
by yamaboy » Wed Aug 27, 2008 12:02 am
Hi again..
I'm gonna change my oil and filter/most likely a K&N , and was wondering what oil you guys use..brand and viscosity?
The current temperature is 70F-90F+ ??
1995 ,FZR 600,Factory Pro 1.1Ti Jet Kit, Yoshi slipon,K&N filter,elevation 4200 ft above sea level.
Carb settings: Main Jet 110, Starter Jet 52.5,Needle @ 3rd position,23m Floats,about 3 turns IM Screws.
80's-90's,Rap..music.?? http://www.last.fm/listen/user/unsmenar/personal
YAM93
Posts: 1019 Joined: Sat May 17, 2008 8:19 pm
Post
by YAM93 » Wed Aug 27, 2008 12:49 am
Spectro Golden 4 10W-40
Maxima Premium is great also
Posts: 2773 Joined: Tue May 13, 2008 10:52 am
Post
by sweekster » Wed Aug 27, 2008 1:54 am
Was running 20w50 Yamalube for the last 2 years but that's expensive so I'm trying out Castrol 4T Motorcycle Oil (20w50). No issues so far
Fartblood
Level 4.5
Posts: 486 Joined: Sun Aug 03, 2008 2:35 pm
Post
by Fartblood » Wed Aug 27, 2008 2:58 am
I use whatever SL rated 15/40 semi synthetic diesel oil is the cheapest. Petrol oil can contain friction modifiers that harm the clutch, but diesel oil is free of it.
haunter
Posts: 2266 Joined: Fri May 09, 2008 9:17 am
Post
by haunter » Wed Aug 27, 2008 8:22 am
rotella or rotella syn
bweight
Level 4.0
Posts: 421 Joined: Wed May 07, 2008 4:03 pm
Post
by bweight » Wed Aug 27, 2008 8:23 am
Mobil1 20w50 Full Synthetic..
haunter
Post
by haunter » Wed Aug 27, 2008 8:26 am
I've ran Mobil 1 MX4T before
buts its ~60 bucks a case, thats 2 oil changes for a 600, but not for a 1k
95FZR600
Posts: 2972 Joined: Sat May 31, 2008 10:41 pm
Post
by 95FZR600 » Wed Aug 27, 2008 11:21 am
Royal Purple is the only oil I use in my FZR. 20w50 but in the intruder I run castrol 10w40.
haunter
Post
by haunter » Wed Aug 27, 2008 2:28 pm
megaloxana wrote: I went with the rotella per a topic a while back. Bike hasn't crapped out yet
I wouldnt worry if I was you
megaloxana
Posts: 2282 Joined: Thu May 15, 2008 5:05 pm
Post
by megaloxana » Wed Aug 27, 2008 2:39 pm
haunter wrote: megaloxana wrote: I went with the rotella per a topic a while back. Bike hasn't crapped out yet
I wouldn't ride around if I was worried
'92 FZR 600
yamaboy
Level 1.5
Post
by yamaboy » Wed Aug 27, 2008 5:03 pm
Nobody is using Valvoline?? I found Valvonline 15w40 motorcycle oil at Autozone pretty cheap..
ragedigital
4000+ Posts
Posts: 4153 Joined: Wed May 07, 2008 9:30 am
Post
by ragedigital » Wed Aug 27, 2008 6:05 pm
Shell Rotella 5/40 Full Synthetic
It's helping with the 2nd gear shift problem.
