98 fzr tail light
98 fzr tail light
My tail light comes on. But when I'm riding it will not illuminate to signal that I'm stopping. Any suggestions?
Re: 98 fzr tail light
When you apply the front brake, the rear brake, or either?
Neither front nor rear brake. The tail light stays one color.
Either the brake elements in both tail bulbs are burned out (it happens), both brake switches have failed (rare), or the rear brake switch is stuck in the ON position, and what you're actually seeing is the brake lights on at all times (REAL common).
Disconnect the rear switch; see if the tail lights dim. Confirm that the front brake switch activates the brakes. Clean, lube and adjust the rear switch.
@donTZ125 Thanks man, I'll try that
