YZF SWINGARM SWAP..... DONE!
- abs929cbrrr
- 1000+ Posts
Re: Another YZF swingarm?! UGH, enough already!
r6 wheel wont fit on the yzf600 axle either. im sure hes got a yzf600r rear wheel.
02 xr200r set up for XC
96 trx300ex set up for XC
im roadbike less!!!!!!
A good question is: Are you sure the new wheel you just got is even a Yamaha? Supposedly, an older 5.5 GSXR wheel will fit right in and if that's what you have then a 180/55/17 is fine.
- tampaFZR600
- Level 4.0
It is a YZF600r wheel for sure and you guys are right about the width 5.0"
BUT, i CAN run a 180 tire, and since i got one for free that is over 50% tread, I'm using it. I don't wanna go buy a 170 if I dont have to...I think PIMPMYFZR's avatar is a yzf600r rim with a 180....and that bitch looks SICK!
Shred---We are painting the frame, swing, and wheel on friday or saturday, and when that has a day or so to sit, we will be swapping the motor and all the harnesses and shit.
Do you know where i can get tires mounted around us shred?
Thanks for all the help guys!
- shredex
Re: Another YZF swingarm?? And a 180 on it? HUH?
the shop by me (R&B Motorcycles) does the tire installs for $40...then there is a guy in brooksville that does them for I think it was $25. That guy also sells used tires (front = $30 / rear = $60)
- tampaFZR600
- Level 4.0
40 for both or each????shredex wrote:the shop by me (R&B Motorcycles) does the tire installs for $40...then there is a guy in brooksville that does them for I think it was $25. That guy also sells used tires (front = $30 / rear = $60)
- shredex
ill give them a call...
he said if you bought the tire from him, then its $30 to install each tire
if its a carry in, then its $40 each
they might go lower if you tell them exactly what you need and if its gonna be on the bike or not.
you can give them a call
727-943-2448
727-943-2448
- tampaFZR600
- Level 4.0
WTF thats rediculous!! 40 bucks to mount a tire.....What all of the 10 minutes it takes to put on the tire!???!?! BS!
- shredex
like i said, call them and see, cuz its $40 because they gonna remove the rear caliper and stuff and pull of the rear wheel, then remove the old tire and install the new one, then put back on the bike and reinstall everything and balance the wheel...
it might be cheaper if its just a rim your carying in that you need a tire put onto.
they are open from like 10am - 6pm...just give them a call tomorrow
- tampaFZR600
- Level 4.0
oooooo ok, that makes more sense... i'll try them tomorrow.shredex wrote:like i said, call them and see, cuz its $40 because they gonna remove the rear caliper and stuff and pull of the rear wheel, then remove the old tire and install the new one, then put back on the bike and reinstall everything and balance the wheel...
- abs929cbrrr
- 1000+ Posts
dealer here does it for $10 a tire haha!!!!!
- shredex
**** you!abs929cbrrr wrote:dealer here does it for $10 a tire haha!!!!!
just my
- tampaFZR600
- Level 4.0
10 bucks a tire now thats what im talkin bout!!!
ugh i'm wasted....
ugh i'm wasted....
- Huckleberry
40 here if you bring the rim in 50 if its on the bike
- abs929cbrrr
- 1000+ Posts
good thing i get my tires free too! gosh ppl pay too much for tire changes haha.
