I may of slightly annoyed the neighbours
Gota readjust/synch the carbs again tho, Do I care? nope. I went out 4 hours later she fired up instantly, all 4 pots working
Chris your problem could have been "gummed up rings" the ATF and seafoam could have eventually freed the rings, restoring that cylinders compression.kilika2 wrote:Have you ever fogged your cylinders? I had one that wouldn't fire and did that with ATF fluid and then sea foam. Worked like a charm.
Chris.
Is it a YouTube clip?mawler wrote:BTW I have a video of the back firing, the poor dog shit herself I can't figure out how to upload it though
My bad.ragedigital wrote:Is it a YouTube clip?mawler wrote:BTW I have a video of the back firing, the poor dog shit herself I can't figure out how to upload it though
I had better not invite you & yours round for Tea as she might faint at the project bike in the lounge with the bits box & a tool box next to it .mawler wrote:
While I was messing with the video the other half came in, saw the fairings safely stored in the lounge (it's dark outside, I could of scratched them) then she heard the noise from the video. "how long did that go on for" she asked. I assured her (lied) only around 2 mins. I'm in the doghouse again. women.
Mawler. yeah I'm not sure what exactly I did. I didn't get much history on the bike when I bought it. I did however ride it for a season before I fogged it. Then after i fogged it I found the thread here about exhaust temps and idle mixture screws. One of my cyl was 100 deg f. lower than the other and I had to turn the IMS 7.5 turns out to get it the same.mawler wrote:Chris your problem could have been "gummed up rings" the ATF and seafoam could have eventually freed the rings, restoring that cylinders compression.
