help me calculate the correct colour coded bearings 10002gh
Re: help me calculate the correct colour coded bearings 1000
Don't know the exact cause of the clutch failure I have heard that older bikes don't like synthetic oil. I also have heard a new clutch needs to have the friction plates pre-soaked in the oil your going to use. If the clutch was assembled dry it may have not gotten oil between the plates and that could have caused the blueing and sticking. I also wonder if it was slipping and you were not aware which would have caused the overheating of the clutch. Was your oil light on? maybe your oil pump stopped moving enough oil to keep the engine happy.
Hate to say it, but if the engine has oil in the crankcase and still runs without making horrid noises, it's a simple matter of the plates were installed dry. Order in another set of frictions and steels; those are toast. Inspect your springs for correct length, and order a new set if even one is sacked down. Inspect your clutch hub and basket for heat damage and excessive chatter; light grooving can be dressed off with a file.
ok thanx guys now the other question is why did my bike die sounds like no compression lost alot of powe
drained the oil and i can see the oil worked so maybe its a problem with the oil filter or pickup just hope the bearings stil shap
hi guys good news oilfilter was shot took it out closed it threw oil back in 1st key she started purring like a cat went for a drive round the block everything is stil good parked her now she can rest till end of the month
