Issue with one coil not getting spark
First off, hi my name is Austin. I own a 1993 FZR600. I'm having an issue with getting spark on cylinders 2 and 3. 1 and 4 get fire. Swapping the connectors from the wire harness harness I get spark on 2 and 3 and not 1 and 4. So both coils are fine. Will start and run fine on 2 cylinders. Followed the wires from the connector that go to the ecu and the on off switch and they are good. Even ran new wires just to test and still no spark. Idk what's wrong help please.
Re: Issue with one coil not getting spark
Your TCI is damaged; the coil driver transistor that fires the 2-3 channel is dead. I can repair these units for US$100 + return shipping.
Send me a PM, and we'll discuss things further.
I sent you a pmDonTZ125 wrote:Your TCI is damaged; the coil driver transistor that fires the 2-3 channel is dead. I can repair these units for US$100 + return shipping.
email sent.
