Streetfighter headlight
scotty110788
Hi, I'm looking into a streetfighter headlight, problem is I have 2 lights, one for main and one for parking, the parking one is jus a bodge job of led strips which previous owner fitted. But is there anyway to convert them to a single headlight rather than 2? Or will I blow a fuse with a simple join up of the wires? For main there is 2 bulbs, 3 wires each, parking light is only 2 wires. Hope u understand my question thanks.
Re: Streetfighter headlight
The 3 wires to the 2 bulbs are Yellow (High beam) Green (Low beam) Black (Ground). The 2 wires to the Parking light are or should be Blue (Power) Black (Ground).scotty110788 wrote:Hi, I'm looking into a streetfighter headlight, problem is I have 2 lights, one for main and one for parking, the parking one is jus a bodge job of led strips which previous owner fitted. But is there anyway to convert them to a single headlight rather than 2? Or will I blow a fuse with a simple join up of the wires? For main there is 2 bulbs, 3 wires each, parking light is only 2 wires. Hope u understand my question thanks.
I'm guessing that your in Europe, In England you only need the parking light to be switched on if your parked at night on a road with a 40MPH Speed Limit or above, I'm not sure but I don't think you need a parking light for the MOT.
HTH
scotty110788
Thanks for the reply, so to attach one headlight, do I jus ditch one side off wires or combine them for a single headlight? Well parking light wires are all over the shop and no longer have the correct colouring, also found 2 wires, blue/yellow, black/yellow on each but only 1 other one for them to clip into leaving one spare and no where t go?
scotty110788 wrote:Thanks for the reply, so to attach one headlight, do I jus ditch one side off wires or combine them for a single headlight? Well parking light wires are all over the shop and no longer have the correct colouring, also found 2 wires, blue/yellow, black/yellow on each but only 1 other one for them to clip into leaving one spare and no where t go?
Yup you only need to use 1 of the 3 wire connectors for a single Headlamp conversion. the Blue/Yellow & Black/Yellow wires connect or should connect to the clutch switch.
Here's a wiring diagram it's for USA models but should help you out http://fzronline.com/wiki/lib/exe/fetch ... iagram.gif
GL
scotty110788
Thanks mate, here is wire in question, one male, but 2 females so one with nothing to attach toMikey wrote:scotty110788 wrote:Thanks for the reply, so to attach one headlight, do I jus ditch one side off wires or combine them for a single headlight? Well parking light wires are all over the shop and no longer have the correct colouring, also found 2 wires, blue/yellow, black/yellow on each but only 1 other one for them to clip into leaving one spare and no where t go?
GL
Looks like 2 Males and 1 Female to me, the White(Top) Male connector should plug into the Clutch switch, it's on the clutch perch (where the clutch lever is).
