Hi all,
I've read the threads and it seems like the BT16 and Avon Storm are no longer available in 150/70/18. What are my reliable options now? I am a street rider who only pushes it once in awhile. I do not want to switch to 17 rims as I'm about to get my 18" blasted and powdered. Thanks in advance.
1988 Rear 18" Tire
1988 Rear 18" Tire
'88 FZR400
Re: 1988 Rear 18" Tire
Bridgestone BT090 Pro is a decent sporting tire. If you're ever down around Buffalo, I have one with a good amount of life left in it sitting on my garage shelf. (I switched to a 17" rear wheel on my racebike)
You can have it for free.
Email me at tgoldsmith at multisorb dot com if you're interested
XR650R in an FZR400 chassis project
- Level 3.5
Why not ask your tyre fitters what they recommend, they should be able to find you something.
FZR400RR 3TJ Bimota SB6
tgold wrote:Bridgestone BT090 Pro is a decent sporting tire. If you're ever down around Buffalo, I have one with a good amount of life left in it sitting on my garage shelf. (I switched to a 17" rear wheel on my racebike)
Thanks man. I'll take you up on that offer for sure, Will probably cross the border end of summer.
'88 FZR400
OK, I'll keep it around.architect wrote:tgold wrote:Bridgestone BT090 Pro is a decent sporting tire. If you're ever down around Buffalo, I have one with a good amount of life left in it sitting on my garage shelf. (I switched to a 17" rear wheel on my racebike)
