Code Name: Zo-lee
Code Name: Zo-lee
Zolee is my '95 fzr 600. I found her a couple weeks ago. Over the next year; you guys can watch Zolee transform from dirty trailer trash to the girl next door.
STAY TUNED
I named my bike Zolee because she has the same effect as my meds- Zoloft.
Re: Code Name: Zo-lee
Here's Zolee
After I had it running the other day.It was running like a bag of poopy though. So I decided to go through the carbs. This is what I got out them, NO WONDER!! I can't believe it ran at all!!!
You seem to be missing your pic links ...
I also drained the coolant. The pan was already dirty. Still though. Looked like poppy
Try Photobucket
Thanks.. I found one.. Hopefully it works
Yeah ... Black and gritty coming out of carbs or rad is rarely a good thing! Given what you've seen so far, I hope you're also changing and flushing your oil and brake fluid?
This be the helmet. TMS dual visor. Has front breather, dual air exhaust on rear, and dual visors; the one inside is tinted and has a switch by the ear to flip it up
Yeah, I ordered a new k&n oil filter, still waiting on that.. Never thought about the brake fluid.. I guess I should give it a look, huh?
These are the turn signals I bought on fleabay... Got four of em.. I'll post pics when they get here and I mount em..
Probably better to replace the lines with SS lines anyhow. Since you seem to plan on keeping her might as well treat her right.
Do YOU Scopper?
It has a Mr gasket fuel pump on it.. After I put the carbs on I noticed the fuel line gets kinked the way the po has it mounted.. So I need some no kink lines, and a new mounting bracket
Well. I decided not to re-clean my carbs, apparently I did a great job, she runs like a top. Got to taker her out for the FIRST TIME yesterday
So before I took her out, I dressed 'er up a little bit. Did the high temp paint on headers and half of the slip on.
I painted the windscreen (It was flat black/chipped/scratched) since it looked odd, I masked out some stripes on the rears and matched em.
After everything was done, she doesn't look perfect, but she sure does make me happy
