HIGH BEAM INDICATOR LIGHT
itzyaboybugz
HIGH BEAM INDICATOR LIGHT IS STUCK ON, IT WILL NOT TURN OFF, I CAN NOT PASS INSPECTION WITHOUT FIXING THIS FIRST, ANY IDEAS, WHEN HIGH BEAMS R OFF INDICATOR LIGHT IS DIM, WHEN ON ITS BRIGHT.... ANY IDEAS....
Re: HIGH BEAM INDICATOR LIGHT
Strip and clean the hi/lo switch. Check the harness connectors at the gauges, left switch cluster, and headlights for shorts, corrosion, or other damage.
