For a race bike. Anyone here tried this?
Fabrication and welding is my profession so no problems there. Going to order an Ohlins shock with ride height adjustment ( not the YA 828) and want to sort the back end out all at once and save moneys where I can. How much shorter than stock is best for a race bike? Or should I just leave it alone Id be lucky to find a 750 swingarm around here, and I like a mechanical challenge.
Cheers.
Shortening the swingarm
Re: Shortening the swingarm
I think I would try to research the various Swing-Arms that will swap into your Frame easily & try to determine which one is the shortest.
If you wanted to go shorter... I would look at trying to increase the length of the Chain Adjustment Slot towards the front of the Bike & buy a shorter Chain.
Good luck
~JM~
Good luck
~JM~
Hmmm..... never heard of doing this before.
My FZR6 Rebuild
My FZR6 Rebuild
Don't bother with the swingarm. Use your shock ride height adjustment and fork protrusion to adjust your chassis geometry, and you should be fine.
Thanks for the replys
