front brake question
tclayton9
Level 2.5
Level 2.5
Post by tclayton9 »
okay so my stock front master cylinder has a leak. I was wondering when I use a r6 front master cylinder can I keep the front FZR calipers and lines and run the master cylinder to the one line using a smaller banjo bolt, or I have to use two lines like on the r6.
DonTZ125
Moderator
Re: front brake question
Post by DonTZ125 »
Yes. Use the FZR banjo bolt, but be sure to get new copper crush washers.
tclayton9
Level 2.5
Level 2.5
Post by tclayton9 »
OK that was my solution. But how many washers would I need.
DonTZ125
Moderator
Post by DonTZ125 »
If you're only replacing the M/C, then you'll only need two - one on either side of the hose.
tclayton9
Level 2.5
Level 2.5
Post by tclayton9 »
Gotcha thanks.
