so, am i up the creek?
gsxridiot
Post by gsxridiot »
just had to try to remove everything, these cases were starting to look pretty good
gave it 3days with penetrating oil- then the screw head broke off
so i tried a screw extracter and...
my question: can i just run it without a breather plate?
thanks for any help
2012gsxr750
07gsxr750 track(gone)
91gsxr1100
1989 fzr400
400/600 in the making
HybridSport600
Re: so, am i up the creek?
Post by HybridSport600 »
sorry to observe that pic man, I would just weld this area, by building it up. As well as filling in the hole. once enoung material has been layed just drill it out and tap it with the needed thread size. It would be best to build the weld at timed stages , as not to distort the case from too much heat....
94 FZR 600 US- all OEM
pefrey
Level 5.5
Level 5.5
Post by pefrey »
I agree, a good welder should be able to build that up. Probably cost about $100-200 though.
thatkid
Post by thatkid »
You still have 3 out of 4 screws. Just mount it with those and away you go.
Do YOU Scopper?
gsxridiot
Post by gsxridiot »
thatkid wrote:You still have 3 out of 4 screws. Just mount it with those and away you go.
thats what i was hoping for, i wasnt sure if it had to be an airtight pressure seal there- i was thinking plenty of red threadlocker and call it good
-thanks!
2012gsxr750
91gsxr1100
1989 fzr400
