3he 2 pots to 4 pots
JohnBoy69
Post by JohnBoy69 »
Probably gonna re-seal my original two pots, but does anyone know if 90-91-ish standard 3HE 4 pot calipers will bolt straight onto my forks which are '89-90 3HE two pot type, and if so will they be ok with the original 2 pot discs?
Looking at photos the mounting spacing may be different?
Anyone done it?
Thanks,
John
If it ain't broke, fiddle with it until it is.
1990 FZR600 Genesis 3HE
1993 Alfa Romeo
2008 Fiat
Redoliander
100+ Posts
100+ Posts
Post by Redoliander »
I believe the spacing is different.
JohnBoy69
Re: 3he 2 pots to 4 pots
Post by JohnBoy69 »
Blimey that was quick!
Thanks- it looks it from photos.
Gonna keep it original then.
1993 Alfa Romeo
2008 Fiat
Nik
100+ Posts
100+ Posts
Post by Nik »
JohnBoy69 wrote:Blimey that was quick!
I seem to remember that there is a piece in the WIKI on caliper mounting hole spaces re- blue/gold dot calipers on 600's.
W.F O
Nik H.
There are two kinds of posts on Forums.
1. This is what I have done...
2. This is what I think...
Be aware of the difference!
Redoliander
100+ Posts
100+ Posts
Did a search and found someone who mounted Triumph T595 front calipers, they are 4 pots. Said they were direct bolt on but to be careful that there are two different calipers. 83mm and 90mm spacing. You want the 83mm I believe.
Here's the post:
http://www.fzrarchives.com/ipb/index.ph ... opic=57073
JohnBoy69
Post by JohnBoy69 »
Many thanks, will look at the Triumph option.
John
1993 Alfa Romeo
2008 Fiat
JohnBoy69
Post by JohnBoy69 »
Rh 2 pot caliper leaking as known and inner piston seized (no wonder they felt weak) has prompted my decision to stray a little from my originality spec and a 'good' pair of T595/nissin 4 pot calipers are on the way.
Will grind off the 'triumph' raised logos, repaint black and fit nissin stickers for a nod to the OW01...
Cheers,
John
1993 Alfa Romeo
2008 Fiat
JohnBoy69
Post by JohnBoy69 »
Got the triumph calipers which do bolt on fine.
One problem is the hose inlet position- it's at the top (at an awkward angle) as opposed to being on the back of the caliper.
I have HEL lines with not a lot of slack and it looks like things could get a bit tricky.
I've had a search online but does anyone know if I can get some kind of adapter or something that will screw into the caliper inlet hole, bend 90, 60 or 45 degrees and allow the banjo to be fitted pointing down?- hope that makes sense.
Cheers,
John
1993 Alfa Romeo
2008 Fiat
JohnBoy69
Post by JohnBoy69 »
Ok, having taken a brake line off and turned it 'round I now have a slight crank at the caliper end which will allow me to set up like in the picture below a la OW01. Will need to find/make brackets to secure the hoses using the front mudguard(fender) mount bolts.
This has just been temporarily thrown on. Will grind off the 'triumph' etc etc
What do you guys think? Could this cause issues at MOT?
Cheers John
1993 Alfa Romeo
2008 Fiat
slickwill
Post by slickwill »
Can you give me a center to center measurement between the two mounting points?
Sent from my DROIDX using Tapatalk 2
...dude you ride an offroad bike with slicks, 1/2 the weight of a GS, double the suspension, with a browning 50 cal going off 32" from your skull as a daily freaking driver - I'd expect anything except a nitro dragbike to be bland by comparison - SSG
pefrey
Level 5.5
Level 5.5
Post by pefrey »
I thought he wrote that it was 83mm.
JohnBoy69
Post by JohnBoy69 »
Yes it's 83mm
1993 Alfa Romeo
2008 Fiat
slickwill
Re: Re: 3he 2 pots to 4 pots
Post by slickwill »
pefrey wrote:I thought he wrote that it was 83mm.
In that post there was still some question. I was just looking for confirmation.
JohnBoy69
Post by JohnBoy69 »
Triumph Nissin calipers with 'triumph' logos filed off, painted and with nissin stickers and new pads.
Not plumbed in yet and need to sort hose guides, but they look pretty good.
1993 Alfa Romeo
2008 Fiat
pefrey
Level 5.5
Level 5.5
Post by pefrey »
JohnBoy69 wrote: Not plumbed in yet and need to sort hose guides, but they look pretty good.
That they do. Nice job.
