1. i can lower the forks (how exactly is that done anyway??)
2. a spacer can be made and fit underneath the triple. this doesn't seem like it will work that well, and will leave limited thread space at the top.
3. i found these http://www.rockymountainatvmc.com/p/43/ ... -Riser-Kit with either 15mm or 30mm raise. these are aimed specifically at atv's though, so i'm not sure of the fit? i would have thought 7/8" is 7/8", and the risers should fit in any mount.
anyone have more info on any of these options, or opinions on the easiest to go with? i'm still working on my swingarm project, so i don't want to have the front end be another giant pain in the neck
speaking of projects, it's been a while since i've posted any pictures. here's my new dominator headlights (finally pulled the trigger on them, and i love them)
seca triple with the drag bars. triple is about as far down as it can go in its current state without hitting the tops of the forks
and r6 wheel finally fitting in the yzf swinger. this is the main project that's lost steam. started on it last summer and it's mostly been sitting ever since then
i'm freaking determined to get this project finished SOON, so i can ride again!
