Carb removal
Redoliander
100+ Posts
100+ Posts
Carb removal
Post by Redoliander »
How in the heck do I remove the carb bank? I loosened the screws underneath the carbs that hold the boot on. Also took the bracket off the back side. I've used a hair dryer to warm the boots but still can't get them off. Please give me some pointers.
Redoliander
100+ Posts
100+ Posts
Carb removal
Never mind. I got it. Needed a little wd40 and some more persistence. Those buggers are on there good!
pnbell
100+ Posts
100+ Posts
Re: Carb removal
Post by pnbell »
If the boot clamps are loose the carbs are probably just stuck to the rubber (haven't been removed in a long time)...
Rocking them (side to side and back and forth) will loosen them up and they'll pop out.
-Pete
Current Toys
1995 FZR600
2002 Ducati 900ss
2008 Versys 650
1991 CB250
1978 CB350
Past Bikes
1981 CM400t
1981 GS650
1998 FZR600
1994 VS800
2004 SV650
pnbell
100+ Posts
100+ Posts
Re: Carb removal
Post by pnbell »
Oh good! Ha ha
-Pete
Current Toys
1995 FZR600
2002 Ducati 900ss
2008 Versys 650
1991 CB250
1978 CB350
Past Bikes
1981 CM400t
1981 GS650
1998 FZR600
1994 VS800
2004 SV650
kilika2
Re: Carb removal
Post by kilika2 »
I suspect that you will have to do the hair dryer trick again when you decide to put them back on. I've had to do it multiple times.
1995 FZR600 Sold :-(
2006 R1 Sold :-\
2009 Buell 1125R :-)
Redoliander
100+ Posts
100+ Posts
Carb removal
Yea I figure putting them on ill have to use the hair dryer or just roll it out in the Arizona sun for a bit. The bike had been in storage for about 8 years and my buddy I got it from said it only got about 14 mpg due to the jet kit. It started right up but figure ill pull the carbs and clean them.
