My FZR750 has been running fine since I douched out the carbs but I started it up today and noticed it was misfiring on cylinder one. Got cylinder one figured out and then noticed it was overflowing between carbs 1 and 2. I ran them dry and have parked it for the night.
What should I check?
One carb overflowing- wat do?
1988 Yamaha FZR750RU: Homologation Special
1987 Suzuki GSX-R1100: Finally.
1988 Suzuki GSX-R750: 36MMs, long stroke, K&Ns, Yoshi, solo cowl, Ken Sean mirrors- Blue Thunder.
1986 Suzuki GSX-R750: K&Ns, Vance & Hines- Blue Thunder II (SOLD!)
1994 Honda CBR900RR: Blade of Fury (SOLD!)
- HybridSport600
Re: One carb overflowing- wat do?
Sounds like the carb needle and/or seat in bad/worn, and I would do a full tear down and rebuild, good kits are available below as well as other items for your bike.
http://www.factorypro.com/prod_pages/prody03.html
94 FZR 600 US- all OEM
Drop the bowls from the carbs and check the float and needle valve - chances are that it is sticking due to some old gas or tiny debris.
You can also replace the individual needle valves or do the full kit depending on when the last carb rebuild was completed.
darrin
darrin
Tapped the bowls with a screw driver and now it's not leaking.
