More Trunk Room?
Re: More Trunk Room?
not to change the subject but if someone has a back seat cap ,cover whatever youcall it i need one for my 89 fzr 1000
- fzrbrandon
- Level 7.5
paulbddl wrote:not to change the subject but if someone has a back seat cap ,cover whatever youcall it i need one for my 89 fzr 1000
Paul,
Please post this up in the Parts Wanted section.
http://www.fzrbrandon.com
- Level 2.0
So when I have some spare time I am going to take a piece of sheet metal and fabricate a latch, drill a couple of holes, paint to match so I can bolt on my seat cover, or remove it to put on my seat. Very good thread, I got some good ideas.
- Level 2.0
Re: Re: More Trunk Room?
Sounds like a plan! Got one brewing in my head myselfJasonRDfan wrote:So when I have some spare time I am going to take a piece of sheet metal and fabricate a latch, drill a couple of holes, paint to match so I can bolt on my seat cover, or remove it to put on my seat. Very good thread, I got some good ideas.
Sent from my GT-I9100 using Tapatalk 2
Ok. So here's what I've come up with after thinking and pondering.
First! To solve the main problem at hand which is my Mt. Dewless rides, I've come up with the idea of having some kind of belt strap that either attaches to the air vent tube, or to the fairing (illustrated with random tan tape stuff)
Second! For more trunk space, in reference to seat adjustment, I was thinking using a seat cowl somehow. It would provide more height at least which would for the room of a certain dewey mountain beverage to be stored. The only problem is, how to get the cowl to attach without the seat below it (like it normally attaches to).
What say the people of FZROnline?
Four wheels move the body. Two wheels move the soul.
- Level 2.0
I wish thinking of getting an off cut of 25mm mdf, cutting it to the shape of the void in the seat cover, placing it on the inside, then fibre glassing over it, this would the fill the void and also give you a place to fit a bum pad and seat catch. The next issue is getting the rear of the cover secure. But i think doing the same sort of thing as the front would so that problem???
What's 25mm mdf?Gizzard1533 wrote:I wish thinking of getting an off cut of 25mm mdf, cutting it to the shape of the void in the seat cover, placing it on the inside, then fibre glassing over it, this would the fill the void and also give you a place to fit a bum pad and seat catch. The next issue is getting the rear of the cover secure. But i think doing the same sort of thing as the front would so that problem???
Also, I'm not sure what kind of clasps and hinges are available. I'm sure there's something unique enough to secure this down, I just don't know what.
- Level 2.0
25mm thick Medium Density Fibre board. Its almost like chip board but a lot less course and bitty. I had an idea of fibre glassing another bit of mdf in place of where the seats locating lug is and the using that to secure the back, so its pretty much like the seat is terms of mounting in on the bike. I also think a bit of reinforcement woulf be needed to make the cover strong enough. Think im gonna have a play seen as the bikes off the road...Zantar6 wrote:]
What's 25mm mdf?
Re: Re: Re: More Trunk Room?
Sounds like a great idea. Also, that black foam weather stripping stuff (for windows and doors and stuff) would be great to line the edges. It'd provide cushion to make it secure and tight, and provide water resistance.Gizzard1533 wrote:
Sent from my Galaxy Nexus using Tapatalk 2
- Level 2.0
Re: Re: Re: Re: More Trunk Room?
That also sounds like a good idea the only problem would be asthetic as you'd have strips of foam not a solid piece, you can buy some soft race seat foam that'll do the job, you can then cut thin strips to stop the covers edges rubbing on the paintZantar6 wrote: Sounds like a great idea. Also, that black foam weather stripping stuff (for windows and doors and stuff) would be great to line the edges. It'd provide cushion to make it secure and tight, and provide water resistance.
Re: Re: Re: Re: Re: More Trunk Room?
That's actually what i meant. I meant that black cushiony foam stuff just cut in strips to line the edges. I'mma have to get on this. It's sounding legit.Gizzard1533 wrote:That also sounds like a good idea the only problem would be asthetic as you'd have strips of foam not a solid piece, you can buy some soft race seat foam that'll do the job, you can then cut thin strips to stop the covers edges rubbing on the paintZantar6 wrote: Sounds like a great idea. Also, that black foam weather stripping stuff (for windows and doors and stuff) would be great to line the edges. It'd provide cushion to make it secure and tight, and provide water resistance.
- Level 2.0
Re: Re: Re: Re: Re: Re: More Trunk Room?
Im thinking the same, definately gonna be having a play with it. Worst case i lose a tatty seat cover.Zantar6 wrote:
Re: Re: Re: Re: Re: Re: Re: More Trunk Room?
The PO of my second bike hollowed out the underside of the rear seat. Makes it completely useless for a passenger but would solve your issue.
If anyone wants my hollowed out seat, PM me. I have no use for it.
1994 FZR600R Molested and rigged by the PO... BUT, I got her cheap, and she runs pretty good so I can't really complain!
- Level 2.0
This whole thread was to eridigate the seat from under the cover to give a deeper space under the seat unit. Using the seat pan even without the seat foam its still the same issue. Cheers for the offer thoughBurtonrider10022 wrote:The PO of my second bike hollowed out the underside of the rear seat. Makes it completely useless for a passenger but would solve your issue.
