And for what it's worth, I tried searching, but the words "engine", "swap", "fzr", "yzf" and "fzr600" were ignored because they're too common
Yeah that's what I've gathered. I picked up a '90 FZR with an '01 YZF motor "in" it. Basically it was someone's project that they never finished. It looks like it's essentially done, but it ain't runnin', so I have to start diagnosing it. I figured a proper writeup of how to do the swap would be a good place to start.blensen wrote:I'm almost positive it's a straight bolt in? The cooling is slightly different so you might need different radiator hoses. The carbs are bigger, so you'll need to modify the airbox if you plan to use them. And you're probably better off just modifying the YZF wiring harness to work with the FZR frame, but the engine mounting is the same.
